Sponsored by:
Sponsored by: DashLynx
Noise from engine compartment.
Old 09-14-2008, 05:41 PM
k4mdh's Avatar
Default Noise from engine compartment.
Hard to explain but as you traveling down the road and start to accelerate you hear a noise almost feel vibartion, reminds me of a loose exhaust shield. It has been to dealers twice and two local shops. No one can figure out where its coming from. I had orginally replaced top and bottom motor mount, check all exhaust shields, checked that manifold brackets and bolts tights. Noise does not appear under heavy acceleration. Maybe someone else could of had simlar problem. thanks for any help.
Old 09-15-2008, 12:58 PM
Default RE: Noise from engine compartment.
are you running your AC when this happens, or does it happen all the time?
Old 09-15-2008, 05:21 PM
If you can try to strap the exhaust hanger tight where it attaches to the front cross member and see if it goes away.
nuke
07-20-2010 11:52 AM
gatorbrit
10-09-2009 08:26 PM
NetAvatar
02-28-2008 05:43 PM
Capo Cam
02-23-2008 10:19 PM
VW
11-30-2006 05:11 PM
Quick Reply: Noise from engine compartment.
