Jrstedham12 |
04-14-2018 12:50 PM |
2004 S60 AWD 2.5T Turbo Swap (K24)
Hi so I have a Snabb FMIC and intake, 3" OBX downpipe, and IPD Turbo Control Valve already installed. Got some new vacuum lines from IPD I haven't installed yet. I also picked up a Borg Warner K24, and plan to install soon. All set to make adjustments to upper charge pipe and turbo inlet from Snabb. Everything else appears to be bolt on, but I keep reading that I'm going to have to redo my plumbing. From what I can see it looks like it will just line up. Is this not the case? Anyone have experience with this swap.?? Help would be greatly appreciated. Once I take my TD04L out, I want to make sure I have everything I need to make the K24 work. Planning on following up with an ARD or Hilton tune immediately after.
