2004 S60 stuck between Neutral and Drive, key stuck
I pulled into a spot and was horrified to learn I couldn't put the car in Park - it just moves between neutral and drive. The key is locked in the ignition. I was able to get it back to my garage, but now the car is running on the battery, stuck in neutral. Help:?
RE: 2004 S60 stuck between Neutral and Drive, key stuck
If you can pull the covers around the shifter assembly off and check down under the selector panel something might be jammed.
dont knwo if this helps but two years ago my dads 950 did the same thing. took off the covers to the shifter and found two tooth picks jammed in the shifter, dad likes to pick will he drives. took em out and all was fine
larry |
