2006 S60 Hesitates & Throws P0193 Code
I recently purchased this car and I am new to Volvos. When driving it will occasionally hesitate / loss of power for a second, and then catch and keep running. Although more recently it happened so bad to my wife that she had to pull off the road. Last night it finally threw a check engine light, and the code reader said P0193 Fuel Pressure Sensor Signal High. Parts store said that would be a fuel tank pressure sensor for about $90, special order.
Does that sound right? Is this sensor hard to get to or replace? I'm not even sure where the fuel tank is on this thing since this is the first I've worked on it! :rolleyes: Hopefully this sensor isn't actually attached to the tank. Thanks for any advice. |
Fuel Pressure Sensor is on the fuel injector rail drivers side one torex bolt one connector.
