5 Codes at Once - Circuit A?
Old Apr 16, 2024 | 07:33 PM
RWACHTMANN's Avatar
Exclamation 5 Codes at Once - Circuit A?
So recently I had the CEL come on, and there were 5 codes present.
The codes are:
P0181 - Fuel Temp Sensor A Circuit Range/Performance
P0182 - Fuel Temp Sensor A Circuit Low
P0193 - Fuel Rail Pressure Sensor Circuit A High
P0243 - Turbo Wastegate Solenoid A
P0343 - Camshaft Position Sensor A Circuit High Bank 1 or Single Sensor
I cleared the codes, and they all came back on the next drive.
The car is running mostly like normal, perhaps it is a tiny bit low on power, but that could be my imagination. The similarity here seems to be that all the codes are related to circuit A, maybe there is a short somewhere or a common component in the circuit failed? None of the wires appear to be damaged, so before I go and start replacing parts, I was wondering if anyone had any input on this situation. Thank you Volvo friends.
cichy1012
Sep 30, 2023 09:55 PM
ProBerry
Jan 29, 2022 08:58 AM
Vaswamp
Jul 24, 2021 02:08 PM
