airbag service light flashing
Hello all
Can anyone tell me if the flashing light on the dash for the airbag to be looked at is a MOT fail in England. Im sure theres nothing wrong with it, because I like lots of others didnt remove the earth lead, before working on the electrics. thanks Adam |
mot fail what?
Originally Posted by SVTfocusO3
(Post 216086)
mot fail what?
If it fails this test, you dont get a bit of paper could a "MOT certificate", and that means your not aloud to drive it on the road. |
I guess you can try a network reset by disconnecting the battery negative and positive and touching them together for 15 minutes. then reconnect...
Yeah alright
You sure 15 minutes is long enough! Or should give it a extra 5 minutes (for luck). |
