battery voltage low message...what gives?
Old Sep 22, 2008 | 05:39 PM
nawlinds's Avatar
Default battery voltage low message...what gives?
I have a 2002 S60...a "battery voltage low" message came up, and a few days later I tried to start the car and got absolutely nothing. Had the battery checked, and it still had the dealer battery in it so I had the battery replaced. I also had the alternator checked at AutoZone and they said it appeared to be working properly. However, on my way home from AutoZone, the "battery voltage low" message popped up again. Any ideas on what the problem is and how much it is going to cost to fix?? Any help would be appreciated...Thanks!
Old Sep 23, 2008 | 06:53 PM
Default RE: battery voltage low message...what gives?
I will bet the Alternator is bad.
Sometimes they will quit charging when hot.
Old Sep 23, 2008 | 08:01 PM
nawlinds's Avatar
I've had the alternator checked already and it checked out fine...anything else that could be causing a drain on the battery?
Old Sep 24, 2008 | 06:02 AM
catalistt's Avatar
get a second opinion on that alternator for voltage output
Old Sep 24, 2008 | 06:21 PM
Make sure the voltage it checked with the car hot and running for a while.
Old Sep 25, 2008 | 10:23 AM
seraphgorny's Avatar
If there is a voltage regulator on the alternator itself replace it. I bet something is burned in there, you shouldnt have to replace the whole alternator if autozone says its charging
volvos80t62011
Sep 28, 2016 10:00 PM
Laptoploon
2001-2013 model year V70
Dec 23, 2014 11:45 AM
catlurver
Apr 28, 2013 04:28 PM
MarksS60
Nov 30, 2010 04:52 PM
gcoladon
Nov 28, 2010 10:23 PM
