Brake Light failure
Brake Light failure
Has anyone experience a problem with the brake lights failing repeatedly. I went to change the bulb, and noticed immediately that the old bulb was way hotter than it should be. I replaced the bulb and while I was testing out the new bulb it burned out as well. I have scheduled a service appt. for my 01 2.4t. But would like to know what might be causing this.
RE: Brake Light failure
Hey tech,
So we got the brake light failure message and took it to the dealership and they replaced the bulbs but they said for them to work some computer module needs to be reset or replaced and want to charge us $700. Does this sound normal? or are they trying to scam? thanks Justin
Yes some of the brake lights work, the dealer replaced two of them, but they couldnt get them to work. they said they tried to load an update in the REM, but couldnt. then stated the Rear eletronic module was bad. however back up, center brake light and some of the other brake lights work, just two big bulbs dont. thanks Justin
So we had the codes ran and no codes came up. However under futher examination we found that not only do the outside brake lights not work, the parking lights stay on all the time. whether parked or not?? anyway, Im guessing there is a bigger problem here. Is there a sensor with the brake pedal/E-brake that could be keeping the parking lights on? but that still doesnt explain the brake light not working. so any information would be helpful. thanks Justin
rburner
04-19-2011 09:14 AM
kosmoscanyon
12-16-2008 12:39 PM
soulfulimpressions
07-31-2008 07:07 PM
