Building struts and shock assemblies for 2013 S60 from scratch
Hi, new here. I need to replace both struts and shocks on my 2013 S60 AWD. Some parts need to be replaced and since the car has 105K and needs new tires, I figured it is best to just get new legs all around.
The problem is that there are no quick strut assemblies which is really annoying. I do not want monroes and only volvo genuine or Sachs. no Bielstein because I beleive there are too hard. So I looked at building my own. Even that is hard because Volvo seems to have myriad of struts and springs for the same car without clear explaination. I cannot even find OEM springs easily online. I will have to call a specialist on monday for that. Meanwhile here is the list of parts I have so far for a full ground up struts and shocks rebuild front and rear: Description Quantity 139622? Sachs Front Right Strut - P3 S60 1 139623? Sachs Front Left Strut - P3 S60 1 235240 Volvo Upper Spring Isolator Damper Ring - P3 2 139396 Volvo Front Strut Coil Spring Lower Isolator Ring - P3 2 120279 Volvo Front Strut Dust Boot Protecting - P1 P3 2 ? Volvo COIL SPRING - FRONT 2 120815 Volvo Upper Spring Seat Strut Mount Bearing - P3 S60 2 120814 Volvo Upper Strut Mount Plate - P3 2 139751 Sachs Rear Shock - P3 S60 2 139395 Volvo Rear Shock Mount - P3 2 Could you guys tell me if I miss anything? thks |
