Buying Volvo 2015 V60 T5 need advice about ring/piston problems ?
Hello.
I'm searching info about Volvo 2015 V60 T5 and founded that there is some faulty models with ring/piston oil problems.
I've chosed this model. It has 75 000 miles. And I even payed small deposit.
Now volvo runs fine but maby I should concern about this engine ?
Im confused, could someone advice me ?
so if engine serial is later than 1501327 for example "1502000" I should not buy it ?
If lower it is ok ? For example 150000
http://australiancar.reviews/_pdfs/V...216_201604.pdf
DESCRIPTION:
If an engine still has a high level of oil consumption despite following TJ30087, follow the actions
described under SERVICE.
SERVICE:
From engine serial number: 1501327, engines have been modified from engine factory.
For service: Change to new pistons + piston rings according the attached service method.
DESCRIPTION:
SERVICE:
