-   Volvo S60 & V60 (https://volvoforums.com/forum/volvo-s60-v60-10/)
-   -   Cel- code p0299/p0193 (https://volvoforums.com/forum/volvo-s60-v60-10/cel-code-p0299-p0193-31908/)
walter351_ Jun 30, 2009 10:33 PM
I own a 2004 S60 2.5T, Vehicle has 66,000 miles on it. I decided to have the spark plugs and timing belt/tensioner/idler changed as a precaution due to other posts that I have read.
I recieved the car back, started and drove it 4-5 times before the CEL came on. Took the vehicle to Auto Zone for a quick code pull and the following codes were identified:
-P0193
-P0299
I have read that the P0193 is most likely the fuel rail pressure sensor, but
I am up to any suggestions
The P0299 code is what bothers me the most. Low boost pressure code. Any suggestions would be great in resolving my problem.
tech Jul 3, 2009 08:00 AM
Make sure they did not knock any hoses loose while doing the work.
redz1006 Jul 4, 2009 05:04 PM
I do not get CEL but every now and then when I check for DTCs
I see P0299 (low boost). I guess it did not occur often enough to cause
CEL.
What hoses do I check ? ALL the ones connected to the TCV
seems to be fine.
Is this a sign that CBV might be failing ?
tech Jul 5, 2009 11:02 AM
It is possible but I doubt it. I would also check the intercooler hoses.
