Check Engine Light / Code
A little help.
My check engine light recently came on ('02 S60 Non Turbo). I went to the local Autozone to have the code read. The reader detected two codes both came up as: P0037 Bank 1 Sen 2 Heater Circuit Low What is this? How serious? How expensive? |
RE: Check Engine Light / Code
I am not sure ...it might be Oxygen Sensor..
Somewhat expensive
Bad O2 sensor. |
Bank one, sensor two, oxygen sensor.
I guess all inline 5's are bank one. Find a diagram and replace it yourself and save $$ I bet a dealer will charge you $350 to replace, net cost of sensor is anywhere from $70 to $180 depending... http://www.car-stuff.com/mmparts/vol...en_sensor.html |
it could be that your volvo oxygen sensor is bad and needs a replacement.. good luck
