control arm replacement
Old Aug 30, 2008 | 10:15 AM
buttone's Avatar
Default control arm replacement
Help helpwill someone give me step by step instruction,tools needed on replaceing control arm assy. THANKS
Old Aug 30, 2008 | 10:49 AM
Default RE: control arm replacement
It is kind of a pain but you will need a 19MM socket 17MM wrench and maybe a 21MM and 18 or 19MM wrench.
The worse part is getting the balljoint back in the control arm when the arm is seated in the subframe.
Old Aug 30, 2008 | 01:18 PM
buttone's Avatar
how too get frame back in ball joint
Old Aug 30, 2008 | 02:27 PM
You installed it to the subframe first correct?
Then you need to pull the arm down and install the balljoint. Yes it is alot harder than it sounds.
Old Aug 30, 2008 | 05:18 PM
buttone's Avatar
Thank you for the advice I turn the wheel,jack up shock tower an finaly I made it happen after 4hour on the first one 1 hour on the second again thanks,you let me know that i had all the tools needed
Old Aug 30, 2008 | 05:38 PM
Glad you got it.
oldschoolrides
Dec 20, 2009 02:07 AM
Platinum52
Jul 17, 2009 07:33 PM
phoffman
Sep 2, 2007 03:07 PM
dpm2340
Nov 26, 2006 01:17 PM
dpm2340
Nov 26, 2006 12:04 PM
