-   Volvo S60 & V60 (https://volvoforums.com/forum/volvo-s60-v60-10/)
-   -   control arm replacement (https://volvoforums.com/forum/volvo-s60-v60-10/control-arm-replacement-22548/)
buttone Aug 30, 2008 10:15 AM
Help helpwill someone give me step by step instruction,tools needed on replaceing control arm assy. THANKS
tech Aug 30, 2008 10:49 AM
RE: control arm replacement
It is kind of a pain but you will need a 19MM socket 17MM wrench and maybe a 21MM and 18 or 19MM wrench.
The worse part is getting the balljoint back in the control arm when the arm is seated in the subframe.
buttone Aug 30, 2008 01:18 PM
how too get frame back in ball joint
tech Aug 30, 2008 02:27 PM
You installed it to the subframe first correct?
Then you need to pull the arm down and install the balljoint. Yes it is alot harder than it sounds.
buttone Aug 30, 2008 05:18 PM
Thank you for the advice I turn the wheel,jack up shock tower an finaly I made it happen after 4hour on the first one 1 hour on the second again thanks,you let me know that i had all the tools needed
tech Aug 30, 2008 05:38 PM
Glad you got it.
