Dipped light trouble
Hi All
V60 D3 2014 I'm having a little trouble with my os headlight (dipped), it's not working, tried another bulb, still no luck!!! Is there a fuse for it as (I may be being blind) can't find it!!! Thanks for any advice/help in advance |
issue may be in the multi-function stalk. Not sure about the wiring for your year but in other models the high beam and low beams are on separate circuits and fuses/relays. My expectation is that its the stalk that does the switching for the "dip" so if you have both working normally then that only leaves the stalk as an issue. Do you have Halogen or HID lights? Any issues with the high or low beams that you know of? (a simple test is to look at the pattern on a garage wall)
After searching through various forums, I took it to a local auto electrician who found a slightly corroded wire and fixed it for £30 (bargain i thought). Thanks for all replies 👍
