Downpipe size vs. performance vs. price
![Question](https://volvoforums.com/forum/images/icons/icon5.gif)
I have been looking at two different downpipes for the s60r. Most aftermarket pipes are 3" in diameter. For example:
High Flow Downpipe
However, elevate offers a 3.5" downpipe which tapers to 3" at the cat.
ELEVATE Volvo S60R 3.5" Downpipe | Elevate Cars
Elevate claims the most performance gains, but they also charge about $250 more for their downpipe than IPD and others [EST as well, I believe].
How much extra "performance" is gained by the extra .5" in Elevate's downpipe diameter? Will it significantly lower the spool time compared to another 3" option? Is it worth the extra green?
Would love to hear from anyone with hands-on experience with any of the aftermarket pipes, but I welcome all replies
High Flow Downpipe
![Big Grin](https://volvoforums.com/forum/images/smilies/biggrin.gif)
High Flow Downpipe
Would love to hear from anyone with hands-on experience with any of the aftermarket pipes, but I welcome all replies![Big Grin](https://volvoforums.com/forum/images/smilies/biggrin.gif)
High Flow Downpipe
$150 PIPE
$100 Cat
$100 labor
$350 and you have an as good Pipe. I along with many others run the pipe Catless using an 02 spacer and No CEL are triggered.
Also while adding the DP will add 3-4 hp You really need to invest in a tune from Rice to get any real performance gains.
Swedespeed Forums - OBX Downpipe
GL
Yeah, I'm just doing my homework at this point, finding out what has worked for others. Definitely planning on a tune as well, and will probably end up doing the downpipe and tune all at once next summer.
Have you been pleased with the OBX pipe quality?? $150 is a ton cheaper than the competition. Sometimes when something seems to good to be true...it is!
Did it fit well and line up with the factory parts pretty well?
Also, I'm in VA and have to pass emissions, so I assume I can't run catless![Frown](https://volvoforums.com/forum/images/smilies/frown.gif)
Thanks for the input and info! You might have saved me a bunch of cash.
![Smile](https://volvoforums.com/forum/images/smilies/smile.gif)
As far as the Emissions test i live in MA and we also have this But as long as they do not get the car on a lift to look for the Cat using a 45% O2 spacer keeps the car from throwing a CEL.
I am in the process of having a CAT welded in (magnaflow 59959 high flow cat) Cost $100 at AdvancedAuto and local Muffler shop said $75 to cut the OBX and weld in the Cat. Even with that im still way ahead on $$. That is $325 all said and done as long as you do the install yourself. Not bad for a 3" downpipe.
I have the whole setup also. For me having an S60 AWD Non-R i had to use the R exhaust . Obx only sells FWD and R . So for me the fit of the exhaust was only OK, The duel tips do not fit right for my car but as far as the sound i have no problems with Drone. But there are other that think its to loud> I do not find this to be an issue. Ill make a clip over the next few days and post it so you can hear the exhaust tone at idle and while driving. Ill make one from inside driving and one while outside. Check back...
Sorry to keep asking questions :P. How does the OBX do on rust and corrosion resistance?
And while I am interested in making the R sound good, I'm more interested in the performance aspect and reduced back pressure. Would I be better off getting just the downpipe and having a custom exhaust put on? A coworker's friend is a master welder and does custom exhaust work on the side. I've been thinking a dual 3" exhaust would look good on the R.
Again, though, this is all just me thinking out loud and I haven't priced out a custom exhaust in rust-prone VA.
Now back to OBX i have had the setup for a year. No noticeable wear/rust but with that said i also am expecting the Exhaust to last as long as i have the car 3-4 more years. So if i was to guess with the feel,weight and finish on the OBX material(steel) 5-6 years+- i feel is worth the price and i don't think that's pushing it.
gccarter
1998-2000 model year V70
09-18-2014 11:47 PM
Peterb123
07-13-2014 08:28 PM
