-   Volvo S60 & V60 (https://volvoforums.com/forum/volvo-s60-v60-10/)
-   -   Error Message - DIP Light Failure (https://volvoforums.com/forum/volvo-s60-v60-10/error-message-dip-light-failure-4677/)
johnsain3 Feb 25, 2006 06:15 PM
Upon startup of 2001 S60t, computer shows error message of "bulb failure, dip light failure."
What does this mean?
It appears that the headlights work on both the normal and bright settings and I do not see an other lights out.
The dealer said it might be the headlights but they would need to inspect it on Monday.
Any opinions or solutions?
tech Feb 25, 2006 06:59 PM
RE: Error Message - DIP Light Failure
That message will be something with the headlights. The dipped beam means low beam headlights. If it was a Taillight it would say bulb failure position light.
johnsain3 Feb 27, 2006 03:08 PM
I took it to the dealer this morning.
Told them that last night the headlights worked, we then drove around the block and the low beam lights did not work.
This morning everything worked fine. This tells me the bulbs are good even though the message says bulb failure.
They checked and said I had a short, then they came back and said that a relay under the dash was not working and that it would need to be replaced but they do not stock them. They will ship it in and install on Wednesday. They also indicated that when they change this part, they must also reprogram the computer to tell it to see or operate the relay. What a crock!
They said the cost would be $180 - $210.
The lights worked fine during my errands after I left the shop and on my last stop, I again received the error message.
On top of all this they said my extended coverage did not cover this part.
I'll give them a call later today, but everyone knows how that goes....
Any other ideas?
tech Feb 27, 2006 09:33 PM
Are you a hands on type?
If so I will walk you through it.
coefamily Sep 17, 2011 10:39 AM
i know this is an old thread, but Im having the same problem. Could anyone give me a walk through
