Fuel Filter
I have a 2004 S60 2.5T. I've read a bunch of threads looking for the fuel filter placement. They say under the car either drivers or passengers side. Not on my car. I have 34300 miles, and have a mid RPM miss, (3800-5000). Starts dropping cylindersand pops a check engine light with P0193 code. Some rumors are that the filter is on the Tank ?? I traced the main fuel line form the take to the fuel rail. No filter to be seen. This is the first problem I've had with the car,, other than that it is a rocket.. easts Rice for lunch. good for the diet ya know.. any suggestions will be greatly appreciated
Pete |
RE: Fuel Filter
The 2004 has a Non-Servicable filter in the tank.
I assume you have a metal tank correct? |
RE: Fuel Filter
That is correct. Metal it is. also the associated check engine light went out all on it's own, don't you usally have to reset it with a computer ??
RE: Fuel Filter
Search the forum. There are posts that list the steps to getting the CEL to go off.
RE: Fuel Filter
The code is most likely still there but and Intermitant fault.
After so long if it doesn't see the fault again the light will turn off but the code is still there. |
RE: Fuel Filter
UPDATE,, I spoke with the dealer about this and they said that there is a recall on 2004 S60's for the fuel rail pressure sensors. just not gone public with the recall. I guess they are fixing them as they come in and owners complain..
RE: Fuel Filter
I got the P0193 code on my 04 2.5T today as well. can someone please confirm that this is actually a volvo recall and they fix at no charge? thanks
RE: Fuel Filter
i would start by calling Volvo USA and give them your VIN, they will see what updates and recalls have or havnt been addressed.
let me know cause i have a 2004 S60 2.5T..... |
| All times are GMT -5. The time now is 07:50 AM. |
