Sponsored by:
Sponsored by: DashLynx
Motor ticking
Old 03-16-2012, 01:38 PM
blankooie's Avatar
Default Motor ticking
This all started in the weeks following an oil change back in the fall. I never noticed the noise, a friend did, and then it preceded to get more and more noticeable. I thought this had to do with the oil filter they put it, so I did an oil change and used a volvo filter, with no change.
The ticking appears to be coming from the head, specifically, cylinder number 2. If I unplug the injector for that cylinder, it goes away entirely. It only makes the noise under load, so if I rev it up, the noise isn't there as the RPMs are dropping.
Here's a video, from a cold start. The noise starts occurring around 2 minutes in. It really doesn't do it much when cold. Could this be the oil sump o rings going bad?
Volvo s60 2.4t motor ticking - YouTube
Old 03-16-2012, 06:07 PM
gabyman97596's Avatar
I would start by doing a compression test to se the diference between the other ones. Try using and additive into the engine like Seafoam in the oil through the oil cap and some lucas oil treatment.
Old 03-17-2012, 02:59 PM
Nichals's Avatar
well fuel injectors make a rhythmic click and the volvo ones are especially noticeable but im not thinking thats what the problem is.
it sounds like the coil pack arching and shorting out. check out your #2 coil and spark plug, swap it out with #4 or 5 do the same thing with the fuel injector if you swap out your spark plug, coil, and injector to #5 and the problem also swaps there's your answer. (im a fan of free diagnosing lol, why throw parts at a problem)
Captain Zov
06-18-2021 12:01 PM
alecw81
05-06-2006 09:42 AM
erdal
05-30-2005 02:51 AM
Ocotillo
03-29-2005 09:14 PM
knight rider
03-29-2005 07:33 PM
Quick Reply: Motor ticking
