Help......
Thank you. I just bought it and i dont know what the previous owner used. Im gonna drive it to empty and fill it with 94. If that doesnt do the trick then i will change the spark plugs. But im doing an oil change today just to be sure. Im just very **** about my car and i want the best for it. I also worry a lot about hurting the turbo. I appriecate the help!
I can save two pages of "discussion".
https://volvoforums.com/forum/volvo-...ium-gas-63832/
I run the recommended premium and lately I've been running it mixed with 1/3 E85. But that's just me.
As for the OP's question. If the manual recommends premium I'd run premium. Recommends isn't the same as "requires" and yes you can run regular if you need to or just want to but the engine will not perform as well. In the manual it states that.
As for playing with a mixture of E85.
Volvo also makes a big point out of telling people you should only use authentic Volvo replacement parts when maintaining or repairing your car.
If we followed that advise we wouldn't have the fun of performance parts. We wouldn't have access to better designed replacement parts and for those of us on a tight budget we couldn't afford to maintain our car if we had to pay Dealer $$$ list for parts.
I'm not recommending anyone else do E85, I only said that I was.
I used my supercharged ford for the test subject and it's been doing better with the mix. Now I'm seeing how it goes with the brick
Recommending not using anything more than E10 and recommending using OEM parts are two totally different things.
Saying the engine will not perform as well on 87 vs 91 is a bit misleading, too. It will perform just fine. It will get the same mileage, it will not misfire, it will not stall out.
They say "Volvo engines are designed for optimum performance on unleaded premium with an octane rating of 91, or above. At least that's what my 95's owner manual says.
It will run on regular unleaded of at least 87 but it's not optimum. What exactly is not optimum, I don't want to find out. There are a lot of threads where people have said poor performance, knocking, poor gas mileage but it might be that their cars condition is marginal and this was the proverbial straw that broke it's back.
markjenross
11-07-2007 08:02 PM
