-   Volvo S60 & V60 (https://volvoforums.com/forum/volvo-s60-v60-10/)
-   -   Help with headlights (https://volvoforums.com/forum/volvo-s60-v60-10/help-headlights-93215/)
screamingchimp Jul 12, 2017 02:28 PM
I have a 2007 Volvo S60. It has the bi-xenon lights. I replaced the driver side bulb and it worked fine when I still had all of the housing off. At that point in time the running lights were not on. I put everything together and now the daytime running lights work but there is only a very dim glow when I turn the headlights on. It's almost as if there's a glow plug but nothing actually ignites the light. Any ideas?
jerick1976 Jul 15, 2017 08:20 PM
Hoping that it's a loose connection either in the wiring or the bulb worked its way loose. with someone looking at the lights I would try moving around the wiring going into the housing to see if things get brighter. I would also look at the reflectors in both housings to see if one has been knocked around. I don't have the Xenon lights but mine were quite finicky unless I had them fully locked into place. Hopefully all you need to do is reseat the bulb in the housing.
screamingchimp Jul 28, 2017 04:11 PM
Thanks Jerick. It was actually that the bulbs came unseated from those prongs. I didn't see any clear instructions on how to remove or reseat the bulbs, so I didn't realize you had to twist the black plastic ring to lock and unlock them in place. Much easier once I figured that out.
