key fob battery burn?
Old Dec 19, 2020 | 03:17 PM
Oprnole's Avatar
Default key fob battery burn?
My 2014 S60 burns through key fob batteries about every 4-5 months. Anyone else see this trend?
Old Dec 20, 2020 | 08:30 AM
ES6T's Avatar
I've seen it once. You'll need a new fob
Old Dec 22, 2020 | 11:24 AM
rickwol's Avatar
We park in our garage and had a habit of leaving the key/fob in the vehicle and lived with this phenomenon for a couple of years and then tried something new. We tried no longer leaving the key in the vehicle and what a surprise, no more having to replace key fob batteries. Not sure if you have this habit as well but if you do, give it a try.
Old May 7, 2023 | 06:03 PM
Johnny Hamm's Avatar
I had the same experience with my 2013 S60. And on occasion the dashboard would say low battery even though it was not.
Cured both issues by turning off the stereo prior to turning the engine off.
Old May 6, 2024 | 09:09 PM
Gil2424's Avatar
Default Fixed
So 8 months ago, I changed both key fob batteries with 4 Energizer batteries, 2 for each.
Now both key fobs showed battery low at the exact same time even though I typically use 1 of them day in day out.
After reading the above comment I suspected a short.
I remeber the thin white plastic sleeve that sits between the 2 batteries was damaged and had a cut out possibly where the 2 batteries could touch.
So I traced out the battery on the front of an Aldi catalogue, popped out the circle and stuck that in the middle of the 2 batteries to add further insulation....
I used the same 8 month old batteries and dash had no more key fob flat battery notifications.
FIXED [img]data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7[/img][img]data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7[/img]
mcgiiver
Jun 28, 2021 08:10 AM
LisaMac8530
Sep 4, 2013 06:25 PM
LisaMac8530
Sep 4, 2013 12:44 PM
jparnes1
2001-2013 model year XC70
Jul 11, 2012 02:31 PM
joejoecat
Feb 9, 2010 09:51 PM
