Limited steering range V60 II D4 2020
![Question](https://volvoforums.com/forum/images/icons/icon5.gif)
Hello,
I have problem in v60 II d4 2020 regarding turning the wheels to the left after damage to the right wheel, the driver's airbag deployed.After repairing the airbag, when I start the car with the wheels straight, I cannot turn the wheels more than 5% to the left.However, if I turn the wheels to the left before starting, let's say more than 5%, and start them with them locked, the steering wheel works in the entire range.After consulting with the guy who made the steering racks, he ruled out a mechanical problem.
codes:
BCM-C005196 Steering position sensor.Component failures.Internal component damage.SAS-C1B0085 Steering Angle Sensor - Bus Signal/Message Failures - Signal Above Acceptable RangeIHU-U2E0468 ECU supply voltage too low - algorithm-based failures - event informationPSCM-U2F0782 Lost Communication with Central Electronic Module (CEM) - Bus Signal/Message Failures -Activity/sequence counter invalid/not updatedPSCM-U2C2162 Incorrect data taken from steering angle sensor - algorithm based failures - signal comparison errorPSCM-U2C3581 Invalid data received in Steering sensor signal - Bus signal/message failures -Invalid serial data receivedSCL-B102694 Steering column lock - component failure - unexpected operationSCL-U2E0468 ECU supply voltage too low - algorithm-based failures - event informationSODL-U2C4981 Invalid data received in SteerWhlSnsrSafe / SteerWhlAg - Bus signal/message failure -Invalid serial data receivedSODR-U2C4981 Invalid data received in SteerWhlSnsrSafe / SteerWhlAg - Bus signal/message failure -Invalid serial data receivedASDM-U2C4481 Invalid data received in PinionSteerAg1 / PinionSteerAg1 - Bus signal/message failures -Invalid serial data receivedASDM-U2C4581 Invalid data received in PinionSteerAgSpd1 / PinionSteerAgSpd1 - Signal/Message failuresbus - Invalid serial data receivedASDM-U2C6292
codes:
