Locking the keys in the ignition
Old Oct 2, 2009 | 05:31 PM
CASS60's Avatar
Default Locking the keys in the ignition
I found this from another thread and I plan on trying it. I live where it's cold and I need to let the car warm up for a time before I jump in and go to work. Anyone else know if this works? I have an 2001 2.4T.
Hi everyone,
I found one way I can lock my keys in the car with the engine running.
(WARNING: If you try this make sure you have the window open to get in your car )
1) Remove key
2) Stand outside with door open
3) Press lock (door latches will lock)
4) Sit in car and start engine (leave the door open/ajar, door latches are still down)
5) Get out of car with engine is still running
6) Slam door shut (Door lacthe is locked and engine running!)
If someone would try this even on a different car. I think the S60 has a minor bug in the logic with this mechanism. WHat should have happened in step 6 was for the doors to unlock when I slammed them closed since the key/engine is running. Maybe they have a software fix. I heard one more person getting locked out like this but they didnt know why either.
My only question is: Do the latches lock automatically if the car has no key (and doors were open/ajar?).
If not, I may have by accident pressed the lock button (which I hate cause you never know if you will unlock or lock unless you take 10 seconds to think about it) and closed the doors without realizing it.
Old Jun 16, 2021 | 01:58 PM
Farrytom's Avatar
Hi everyone,
1) Remove key
take the expert advice from a locksmith because no one here can explain you.
ImOk
Jul 4, 2021 03:48 PM
Per94
Feb 13, 2017 07:54 AM
mainesail
Aug 6, 2016 07:47 AM
cherries
Dec 13, 2010 12:18 PM
rkadfalk
Jun 8, 2009 08:46 PM
