Low beam panic: burnt out
The real panic is how the hell am I going to perform a simple headlight chg?
There is no room to work once I remove the "lid", and if I had room, I am confused as what snaps off to get at the old bulb to remove it.
Any place I can look at some detailed photos depicting this? Would help!
On my S60, on the driver's side (US) I had to loosen the air intake tube and the box that holds the air filter to get to the bulb. There are three plastic "pinch" pins at the bottom of the box - 2 in the front, 1 in the rear. Pull the box up and rotate it away from the headlight. This would be a good time to clean your MAF.
I replaced my sockets with ceramic sockets I bought online from Superillumination.
http://superlumination.com/headlights.htm
I added extra lengths of wire to the sockets so I can pull them further out to make future replacement bulb easier. I also applied dielectric grease to the fittings. On the passenger side (US), there is no easy way to do it. The sockets twist into place. There are thre tabs of different sizes so that the sockets only go in one way. As you hold the socket in the hole, shine a flashlight at tha headlight from the outside. You will see the tabs and can line the up. Then make 1/4 turn. Hope this helps.
Volvo_Neps
1998-2000 model year V70
10-07-2013 10:28 PM
KS70T5M
04-17-2010 09:35 PM
