Low Power from take off
Need help, I have a 01 S60T with 80k. I think that the turbo is not putting out the boost it should at take offs. What can I do to ck. and see if the turbo is working right and do this year have a problem with the waste gate not opening like it should. Can the waste gate rod be adjusted, if so how.
I put a guage on the engine, the vacuum side was -19 and the boost would go to 7 PSI but at WOT. At what rpm the boost should come in at on take offs. I think I should not have to put my foot down to make the boost come in, the boost come in at 3200-3500 rpm but at normal take offs it is around 1 PSI. If the turbo control valve is failing will it do this?
uhmm, so was the car always a pig off the line? Or did it develop this fun way of running? Don't quote me but turning the actuator rod 1 turn is equal to raising or lowering the boost .28 psi. I wouldn't do that though. Since these cars are kinda finicky about that and the computer won't know what to do with the extra boost as far as fueling goes. I once built my own mbc for the turbo on the s60, and the car behaved poorly.
elderzap
11-07-2007 04:58 PM
