Need help
Need help
Hello Everyone.....I had a fuse blow in my 03 s60 which controlled my entire dash, I have since replaced the fuse but now have my SRS-Urgent AirBag Service needed light/warning on....I DO NOT WANT TO PAY $100 to have the module reset when I can purchase a reset tool for future use(if needed) and would like to know where can I buy a reset tool for future use???? Alpha bid did not have one for my car and if anyone can provide me with a website that will have the reset tool for my 03 s60 I would really appreciate it...I know I am looking to spend anywhere from $200 upwards to find this device....obviously my OBll tool only works for codes and does not reset the airbag module! Thanks ahead for any and all help!
Here you go...
http://cgi.ebay.com/ebaymotors/VOLVO...ht_4062wt_1165
or
http://cgi.ebay.com/ebaymotors/2010A...ht_4551wt_1165
Might be a bit more than your were hoping to spend though.
or
Holy crap, that ain't cheap. If I had a repair shop, I'd prob buy one.
How can u be sure that thing would do the job it's suppose to do. It could
only be a cheap imitation and not as complete at that of the dealer. You couldn't
get a refund in case u r not satisfied w/ it, only exchange. They say that over
in China, they could copy or fabricate anything they want. Patsfn, better go to the stealer.
Try this it works great.while car is turned off no key in ignition.
Remove only the negative battery cable from ur battey and place it on top of the positive. Let it sit for about 30 sec. On top . Then reinstall the ground cable that should clear all faults. This is used to power down completly all the mod. If it dont work the first time re do but leave it at least an hour.
okay need2fix so I went looking for the battery....not to sound like an idiot but usually the battery is in plain sight and your able to find, on the s60 i did not see the battery, from what I have read I believe it is on the passengers side but I still did not locate the battery is the battery hidden/in a compartment for a reason??? where would I find this elusive battery......does anyone know where I should be looking I feel like a fool asking this but on my 960 the battery was in plain sight and well this one likes to play hide and seek
The battery is in the trunk on the drivers side under the floor mat. It sits under a plastic shield and a hold-down bracket right next to the spare tire. (I'm assuming that your 03 S60 is the same as the 02 S60 that I had.) You'll need a basic socket set to remove the hold-down bracket that covers the plastic shield.
Now, before you go spending your time with the battery, I can tell you, with a fairly high degree of confidence, that the suggestion above will NOT accomplish anything. It certainly won't hurt anything to try disconnecting the negative cable from the battery and letting it sit for a while, but there is virtually no need whatsoever to touch the negative cable to the positive. It's NEVER A GOOD IDEA to touch the cables of a battery together for any reason. If you're not familiar with electrical work, you can easily start a fire, and/or damage the battery.
The modules "power down" when the battery is disconnected, and will not be reset by simply touching the negative cable to the positive terminal. If that were the case, there would be a LOT of happy do-it-yourselfers out there.
Also, if you do disconnect the battery, you may need to enter a security code into your stereo. I didn't have to do that on my 02 S60, but I've heard that other people have, so make sure you have the code before disconnecting the battery, just in case.
Adam
Adam
MTNBKR yes my s60 is an 03 and i did find the battery in the trunk...thanks for the help, but you don't feel that by disconnecting the battery it will reset the airbag module??? I have tried the put your key in the ignition and reset the trip odometer and turn key to position lll and they did not work....and going to a place that works on volvo's wants $100 just to reset the SRS----->Airbag light, any suggestion that might work from anyone????? Any and all help is appreciated!!!!
Ithe reason being is to power down all modules completly. I'm not going to tell you to do something that will harm ur car. I ain't no back yard mech. as for causing a fire It won't
Not sure if it will reset it but I bet ur ccm power was lost causing that light
This works great with check engine lights after repair. Due to capacitors and resistors staying powered on will not let modules erase codes completly . Works great with etm problems to get back in network.
Unless you've found some amendment to the laws of physics and electronics theory that I'm unaware of, then the additional step of touching the negative cable to the positive terminal of the battery is completely pointless. The act of doing so will not enable some hidden "shutdown" or "reset" feature. Spreading this misinformation as truth is simply ignorance.
__________________
glad to hear u become a master tech. for being a member for 4 years cant wait for my four years. lol
as long as the negative is not on the negative post nothing will happen.
dude if u think it will blow up then dont do it im telling u what i do at times to
return module to network works most times. done this thousands of times. i dint say put a extension from post to post.
and yes the last car that used a code on the radio was the S70
__________________
__________________
__________________
With regard to being a master mechanic, no I am not, nor do I claim to be. I am however a Mechanical Engineer (that's how I know my Physics and Electronics theory) who has been working on cars of various makes and models for about 20 years. I only post replies to topics that I have direct knowledge of, or when I feel that something I know my help the person solve their problem. When I don't have a clue what's going on, I keep my mouth shut.
I have yet to see a post from you on this board that suggests that you have any more than a BASIC knowledge of vehicles in general.
#17
#18
Have u tried this before if not then don't sit here and say it don't work.
If u don't belive it will work then go about your buisness and fix it your way.
I'm just trying to help someone out and u want to come in and act like a rocket
Scientist thank u Bill Nye the science guy.
#20
