Need help drop springs 02 s60
I can't really say I've done this, but I can tell you what Vadis says:
Raise the vehicle. Install the striker plate to secure the spring.
Lower the vehicle.
Remove:
-the clips and fold out the front edge of the side panel in the cargo compartment
-the soundproofing
-the nut for the upper mounting for the shock absorber.
Raise the car
Install a restraining strap between the control arms. Tighten lightly.
Remove:
-the wheel
-ABS sensor and the cable from the wheel spindle
-the brake caliper mounting screws. Hang up the ABS line and the brake caliper.
Remove:
-the screw
-the shock absorber.
Compress the spring.
Remove:
-the grommet
-the striker plate
-the spring.
Good luck.
Lower the vehicle.
Remove:
-the soundproofing
Raise the car
Remove:
-the wheel
Remove:
-the screw
Remove:
-the grommet
-the striker plate
-the spring.
Good luck.
teaberry
Aug 1, 2009 10:16 AM
