Need Help Identifying issue
My tire pressure light came on this weekend, so I checked my tire pressure on all four tires and one was low. I filled it up but as I did i noticed these 2 wires hanging from the front driver side wheel well of the car, I dont know if these wires caused the tire pressure light to come on, or even how long these wires have been hanging thier.. My tire pressure light is still on even though all my tires are filled...
I need help identifying these wires, or how can I easily fix them. Thankyou in advancehttps://cimg4.ibsrv.net/gimg/volvofo...2c1aa1f5d.jpeg |
What year is your car? When you put air in the tires or get new tires, you need to re-calibrate the tire monitors using the center console.
Easiest way to find what those wires are for is to follow where they go. My first assumption is a fog light plug, but the plug is gone. |
Originally Posted by Dingus1
(Post 523872)
Easiest way to find what those wires are for is to follow where they go. My first assumption is a fog light plug, but the plug is gone. 2016 volvo s60..... and if so how do i do that exactly |
- Press the MY CAR key in the center con-
sole control panel and select Settings, Car settings, Tire pressure. - Press OK/MENU, select Calibrate tire pressure and press OK/MENU again. |
(Post 523892)
| All times are GMT -5. The time now is 07:30 AM. |
