Need help installing equalizer to backup cam
2 Attachment(s)
I could swear I found the instructions before, but I can't seem to now. Neither can I see how to fit this thing in-line with anything in the location I thought this part was supposed to go. I even looked online under the corresponding service bulletin TJ 27989. Not sure how I found the instructions a few weeks back.
This is the part: http://www.volvopartswebstore.com/pr.../31471726.html I thought in went in here: Attachment 26753 But I see no way to connect it. The only connector I can see is clearly for a different module entirely. Attachment 26754 :( I swear, I saw instructions online someplace. |
Ok, so I've found this which gives me some clues as to where I *might* be able to install this. I can't find the instructions that pointed to the LR trunk in the OP pic.
The only places I see in the SB diagram to attach the equalizer are either near the camera, or under the driver's seat. https://static.nhtsa.gov/odi/tsbs/20...54148-7155.pdf |
The good news is ... I found it! I'm not crazy!
https://www.dropbox.com/s/7osd35qrih...LETIN.pdf?dl=0 The bad news is ... there is no connector where there is SUPPOSED TO BE ONE. I can only guess there's an error in the docs I've found or something. The doc showing the install of the complete cable harness clearly has no break / connector in it. Whereas the instructions for the equalizer show a cable harness going the same route but with a convenient connection right near the panel. To be honest, I don't see how this equalizer can be installed in that location in my car at all. There's no way unless you can cut the video line and install those connector types. And I'm at a complete loss as to where to find those. |
3 Attachment(s)
In an effort to make this easier to read, I've distilled the issue down to the following.
The short story is that I purchased the in-line EQ that's supposed to fix the flickering backup camera issue. Unfortunately, it cannot be installed into my car. The connection referenced in the docs quite simply is not there. Attachment 26750 Nope, not there. Attachment 26751 Not anywhere. Attachment 26752 Help? |
Weird... I've never run into that. I'll have to double check the bulletin to see if there is a VIN break or something.
1 Attachment(s)
Originally Posted by ES6T
(Post 450401)
Attachment 26749 So there's either an error in the knowledge base OR they replaced the harness at some point with one that does not have the connection break. Although the latter doesn't really make sense. Why would Volvo sell a harness w/o connection break? In looking through my service logs, which are likely incomplete since they're from Carfax, I don't see a prior reference to replacing or fixing the backup cam. This one is seriously teaching me some patience. I'm having a hell of a time getting this backup cam fixed. |
2 Attachment(s)
No love at the camera end. It is the same basic cable inside, but the connectors are just too different. They won't fit. Believe me I tried.
Attachment 26747 Attachment 26748 What's even more confusion is, how is there ever a connector there? If you look up the harness as a replacement part, it clearly doesn't have the connector. 2011 Volvo S60 3.0l 6 cylinder Turbo Harness. Camera, Accessory, Electrical - 31414655 | Volvo Parts Webstore, Oak Park IL I also removed the upper trunk lining to see if there might be a connector there. No luck. It's like the volvo parts web store image, just one long cable. I am indeed a sad panda. |
1 Attachment(s)
So I cleaned the cable and the camera connector points with contact cleaner. While I was back there, I decided to try an experiment. The plastic connector clips on the EQ video cable are removable, if you're careful. So I did. As I suspected, it is possible to connect the EQ with the "naked" cable directly to the camera. I tested it and it does work as in I do get video.
Attachment 26746 But it's not warm enough today to trigger the glitch/problem and I didn't feel like taking off the upper trunk liner again. So I'm going to see if cleaning the contacts does anything for now. If not, I'll put the EQ in via the "naked" cable method and secure it in place with some fancy high temp engine bay tape (better than electrical tape imho) and maybe even wrap it in some silicone tape for good measure. If that works, I think I can 3d print some clips that lend themselves to being taped or zip tied to the OEM ones securely, if it comes to that. The "naked" cable endpoints do have a collar that the plastic can go around. |
I'll see what I can dig up tomorrow. What's your VIN?
Thanks. PM sent.
2 Attachment(s)
Turns out you can install the equalizer under the driver seat without actually removing the seat! A fellow over on the Facebook P3 group pointed me in the right direction. I had to swap the cables around, but it looks like I'm in business. Much easier than my plan to attach this thing in the trunk lid, behind the camera. I got about 1/2 way through 3d printing a custom clip for it too. Much happier with this solution.
Attachment 26742 Attachment 26743 |
Hi all,
I have a V60 Plug-in hybrid (D6 AWD), from Feb-2011, bought used and imported from Holland (I'm in Portugal). It happens I had the same problem with the flickering rear cam, specially when in very hot days, but not allways, and sometimes happened when in garage during the night (no high temperature). The seller man talked to me about this item, after my complaint about the issue. But after a close look I found the same situation, continuous cable with no insertion point to connect this kit. So, I tried a slighty different and much cheaper approach. I just put a small ferrite around the cable, just near to the box under the seat. For the moment, and after a month, no flickering!! Have I found the "colombus egg" for this well know Volvo problem?? Let's see during next months... |
Originally Posted by pcorreia
(Post 465714)
Hi all,
(Post 465714)
Hi all,
I have a V60 Plug-in hybrid (D6 AWD), from Feb-2011, bought used and imported from Holland (I'm in Portugal). It happens I had the same problem with the flickering rear cam, specially when in very hot days, but not allways, and sometimes happened when in garage during the night (no high temperature). The seller man talked to me about this item, after my complaint about the issue. But after a close look I found the same situation, continuous cable with no insertion point to connect this kit. So, I tried a slighty different and much cheaper approach. I just put a small ferrite around the cable, just near to the box under the seat. For the moment, and after a month, no flickering!! Have I found the "colombus egg" for this well know Volvo problem?? Let's see during next months... Thanks a lot, Michel |
Just get the CFE+ from Volvotech and be done with all that crap from Volvo
https://www.v-division.com/ |
hello
thanks for your answer but .... How does it solve the problem ?, thanks a lot, cordially, |
Because all you need to do is plug the CFE+ into the OBD 2 port, connect the cam to the screen and good to go. No more screwing around with Volvo`s archaic and expensive setup, that apparently doesn`t even work very well.
Regards |
(Post 465714)
Hi all,
I have a V60 Plug-in hybrid (D6 AWD), from Feb-2011, bought used and imported from Holland (I'm in Portugal). It happens I had the same problem with the flickering rear cam, specially when in very hot days, but not allways, and sometimes happened when in garage during the night (no high temperature). The seller man talked to me about this item, after my complaint about the issue. But after a close look I found the same situation, continuous cable with no insertion point to connect this kit. So, I tried a slighty different and much cheaper approach. I just put a small ferrite around the cable, just near to the box under the seat. For the moment, and after a month, no flickering!! Have I found the "colombus egg" for this well know Volvo problem?? Let's see during next months... Your solution interests me, still no problem since the installation of the ferrite stone? Greeting from France |
Really appreciate this thread as the same thing complete with BSOD started happening when we were in the Carolinas last month. Its now how up here in New England to do it. Part ordered from FCP as my local dealership wasn't competent enough to take an over the phone order.
Follow up question. Does the image on the camera in normal usage improve with this equalizer? Ours has always had a poor quality image. Far worse than our Subaru's and Hondas. |
