Overheating, fan a no go and stalling
65 degrees ambivalent temperature
new fan, recent temperature sensor/sender
140K miles , good shape
Cold start up seems to be normal.
But, when warm, she will quickly start and after a few seconds(varies with the engine temperature) STALLS !
2.74 ohm at the sensor in the thermostat housing ... engine cold ...
help
help
Thank you, I do have trouble reading the scale on a meter !
to add . .
Ohms at the temp sensor … cold … 1.8K … warm/hot … 300
Now the check engine lite is on
9 00 pm 60 degrees …. at start up she ran rough and the idle fluctuated between 1.0K and 1.6K but she then settled down to a smooth 900 and then 700 … idled for 10 minutes .. no stall.
This problem is really "erratic'' !
I suspect a computer .
