passenger side headlight doen't work
I bought new bulbs
checked all the fuses the driver side bulb is the only ones that works. my high beam works. so any suggestion would help thank you. |
When you replaced the bulbs how did the wiring and plug look? Did you see any corrosion or heat damage? I would start by looking it over closely.
I had a turn signal socket go bad. The bulb still worked, but when I went to signal it went bonkers. No obvious damage to the socket. I replaced it and everything has been fine. I hope that helps. |
