Power Window Problem
Old Jul 10, 2012 | 09:58 AM
jdsmith's Avatar
Default Power Window Problem
I have a 2006 S60. When I pull the drivers side power winow switch up to auto-up the window all the way, as soon as it closes it goes back down to the position it came from. If I hold the switch up until the window closes, it will stay closed. Any ideas?
Old Jul 10, 2012 | 10:18 AM
odbii's Avatar
Had this problem once. It did not go all the way back but did go up and drop back down a little. The dealership had to re-program the stop position again with their VIDA tool.
Could also be that the windows is tilting a bit when closing and the entrapment stop is dropping the window back. Check and make sure the window is staying straight when going up.
Old Jun 25, 2013 | 05:37 PM
cpaddack's Avatar
I have exact problem on 2006 XC70. How did you correct problem?
Old Jun 25, 2013 | 11:25 PM
ssicarman's Avatar
Try relearning/normalizing the window. Run it up to the top and let it run down. Then run it back up holding the switch. When it hits the top keep holding the switch for about 3-5 seconds. Then run it down all the way by holding the switch down and when it is down all the hold the switch down for about 3-5 seconds. If the window has relearned if should work normally now.
Don't hold the switch long enough to trip the switch circuit breaker/overload protection. This will interrupt the relearn.
Old Jun 26, 2013 | 07:08 PM
cpaddack's Avatar
Default Power window problem
Thanks for the quick responce. Unfortunately, the fix did not work on my Volvo
Old Jun 27, 2013 | 05:18 AM
doublebug's Avatar
door module has lost window initialization.
Issue needs dealer computer to fix.
Old Jun 28, 2013 | 09:37 AM
TacklaNHL's Avatar
So glad someone brought this up.
My 2007 S60R has been doing this for a little while now and I had no idea it was something that others had seen.
My local shop "Volvo specialists" have a VIDA setup, I'll see if they can figure it out.
Old Jan 7, 2019 | 10:13 PM
SMB's Avatar
SMB
Thank you for posting this fix. I had an issue with the automatic up/down feature on my 2015.5 S60 after opening it on a cold and icy day. This fix worked brilliantly!
Old Jan 8, 2019 | 08:40 AM
Pretorien's Avatar
I had a similar problem on a 2009 V70 - DIY approach didn't work and I traded it for a 2015.5 V60 before it was resolved
H-Bomb
Mar 26, 2013 01:05 AM
menguchita
May 29, 2009 08:50 PM
2001V70T5
Oct 3, 2006 09:31 PM
hubmachine
Jun 21, 2006 11:33 PM
bigld
Jan 2, 2006 08:52 PM
