Removing oil pan
2004 S60 124000 miles.
I ran over some rocks and punctured my oil pan. So I'm trying to remove it so I can put another one on. I removed all the bolts and I just can't get it out. I'm able to move it freely as it's detached from the motor, just can't get it out. Any suggestions? |
You'll probably have to loosen the engine mounts, jack the engine from above using a cherry picker and lower the subframe to get it off. Sounds like things have moved around inside the pan due to the hole punch.
Originally Posted by Pmongii
(Post 450748)
Originally Posted by jerick1976
(Post 451134)
thank you for replying. You are right, lifted motor a little came right out and real easy to change. |
