Resistor/blower location
I have a 2004 S60. Does anyone know where the fan/blower resistor is located? I believe that I have a bad fan resistor. The blower works (occassionally) and when it does it doesn't shut off when the car is off. I have to pull the fuse so the battery doesn't die. I was going to start with replacing the resistor but can't find it?
Thanks, Mark |
If you're talking about the climate control fan and resistor, then they are one unit and they must be replaced together. They are below/behind the glove box. How long does the fan stay on? There is a setting where the fan continues to blow when the car is off to dry out the A/C ducts, although it would have to be changed by a professional.
Deucetech, thanks for the reply. I was able to find it. It is located behind the glove box and it does unplug from the blower and can be replaced. I was able to order a new resistor from partsgeek.com for $97.00.
Thanks, Mark |
| All times are GMT -5. The time now is 07:55 AM. |
