reversing lights won't work
hi guys and gals, please help, do the reversing lights work off more than one fuse, both lights just stopped working, I replaced the fuse with a known good one and still no power making it's way to the bulbs, if not what do you thinks it could be......is there a connection under the central console near the gear lever ( shift ) that might have come loose, I ask before removing it to check.
have you experienced it before... Oh, by the way, there are no messages appearing to tell me that they aren't working. cheers mav |
RE: reversing lights won't work
According to the wiring diagram there is a relay for the reversing lights. It is in the rear electronic module.
Thanks for the reply bill, ( I live in stockton so not far from you, presuming your Durham is the north east England )... beleive it or not I got in the car this morning and everything was OK,,,, but will check that the relay is seated correctly .
cheers mav |
Yes, just up the road and we have to communicate via the US.
Keep an eye on it as relayssometimes 'play up' for a time before dying. Of course it may be just a bad connection somewhere. |
