S60 D5, 2004. Headlight bulb replacement
I am struggling to get access to the bulb on UK passenger side. What is the easiest way to do this.
All help greatly appreciated. Dave |
Yes! Managed to get this done
To change the bulb I removed the airbox.
Unplug sensor switch, undo jubilee clip on hose. Airbox is held in with 3 clips that need compressing to get them to retract, used a 9mm socket with extension bar to do this. Pushed socket onto clip then pull up gently on airbox. Easy to get access to inside of headlight once airbox removed. Hope this helps. |
| All times are GMT -5. The time now is 07:57 AM. |
