S60 D5 Loss of power DTC P0244
Thanks for reading my post.
I have a S60 D5 2.4 td and when driving hard through the gears the car seems to loose power as though it is hitting some kind of fuel cut. I have read the ECU and the DTC stored is :- P0244 Turbocharger Wastegate Solenoid (A) N75 Range/Performance Does anyone know the location of this valve? Can you clean the valve? any info would be brilliant. Thanks Gavin |
RE: S60 D5 Loss of power DTC P0244
Find the turbo unit and you will see the wastegate and the wastegate Valve you can follow the hose back till you find a valve like setup.Sometimes it is mounted on the side of the air box or very near it.
