Solid mount upper engine crossbar deally thingy.
So i have been machining up new solid ends for the upper torque mount bar and got them done and threm them in. There is a bit of difference, it seems like the car is less prone to understeer and deflection on bumps in the corners. So that means they are doing their job. I should quit my day job and devote myself to cranking out a line of performance suspension products for Volvos. Next xtop will be billet aluminum end links.
. I'm such a dork. |
RE: Solid mount upper engine crossbar deally thingy.
Any pics?
Not really much to see just two solid cylinders of metal pressed in to replace the half rubber half metal oem units. Though i do need to create some sort of block outs for the adjustable end on the actual flanges that go to the upper mount. Because I noticed that there has been a bit of wear around the bolts. I'll take pictures of those when i get the chance to nake them.
| All times are GMT -5. The time now is 12:56 AM. |
