Starting Problems in hot weather S60 2001
Old Jun 23, 2013 | 04:06 PM
manofsteel05's Avatar
Default Starting Problems in hot weather S60 2001
Hello all. My 2001 Volvo S60 2.4T 148,000 miles starts up fine in the winter and in the morning's in the summer. However, if its 85 degrees or above in the summer and the car is warmed up and I'm running errands, stopping and restarting the engine. The car will crank and sputter before it starts or it will not start. These are the dealers notes from last year: RPM signal not good. Checked for relevant codes none found. Tested fuel pressure it is OK. Found when problem exists the tach bounces and the RPM sensor signal is erratic. Needless to say I declined the extra $300 to pay for more diagnostics. When the problem reoccurred this year I took it to my local Volvo tech and they replaced the RPM sensor at the cost of $180 for parts and labor. That was a waste of money, because the problem persists! My question is, has anyone experienced this same problem and what was the solution? Thanks.
Old Aug 23, 2022 | 03:01 PM
The_Vortex's Avatar
I have that exact same problem and I can't figure it out what the hell is happening!!. did you happen to solve it?
Old Aug 25, 2022 | 05:56 AM
The_Vortex's Avatar
Has anyone had this problem?
Old Aug 25, 2022 | 09:04 AM
I have the exact same problem
Check your residual/rest pressure. If the fuel pump check valve is bad it will be harder to start when hot.
Old Aug 25, 2022 | 10:11 AM
The_Vortex's Avatar
It doesn't have an electronic fuel pressure sensor (2001 volvo S60 T5 2300cc 250hp) but it is not a fuel pressure related. sometime starts just fine even it parked for 5 or 6 days (or even more).
Old Aug 25, 2022 | 10:43 AM
You have to use a mechanical gauge to check fuel pressure.
When starting cold the ECU turns the "choke" on and sprays additional fuel.
Old Aug 25, 2022 | 04:08 PM
The_Vortex's Avatar
is not a fuel pressure related! did you read the entire @manofsteel05 post?! when this happen there's no injector or spark plug signal.
Old Aug 25, 2022 | 04:22 PM
Sorry not trying to **** you off, just offering suggestions.
Old Aug 25, 2022 | 05:39 PM
The_Vortex's Avatar
I know and I appreciate any suggestion but believe me, is not a fuel related issue.
Ashley505
Jun 4, 2016 10:55 PM
Nathan DuBow
Jul 26, 2012 12:46 AM
Neville
Jan 14, 2009 06:19 AM
airapetov
Nov 7, 2008 11:35 PM
ozdemir
Mar 10, 2005 11:08 PM
