Thinking of buying a 2002 S60
Hey everyone! I'm contemplating buying a S60 with an automatic transmission for 2000$. It has 142k and looks extremely well maintained. I'm actually going to see it in person tomorrow and decide if I want to buy it.
I'm more familiar with Honda, Ford or VW/Audi myself. I know with the German cars, timing belts /chains tend to go at 120k, and its good to check for rust under the panels and on the struts etc.
But I'm not really sure what to look got on the S60.
So ultimately, what should I look out for, do you think that the 2002 S60 is a reliable daily or its it notorious for problems and is it recommended to take it to a mechanic to check over it, or would most of the problems be able to be found by me?
Thanks!
Thanks!
Thanks!
Thanks!
Of course do a thorough inspection and definitely double check if the timing belt has been serviced properly.
The automatic transmissions seem to be problematic, there are some stickies regarding common issues and recommended repairs. All around though, the rest of the car is fairly solid, I recently picked up a 2001 S60 and the only issue thus far is the transmission.
Well problem is that he's not sure if the timing belt was done, because it's at 140k and it was bought last year. But he's done a lot of maintenance.
Found out the CEL is on due to a bad speed sensor, so I'm assuming it's a wheel speed sensor lol. But I'm taking an OBD2 scanner to verify, and if all is well, due to the uncertainty surrounding the timing belt, I talked him down to 1400 instead of the 2000 original. I'm guessing the best I can do with the transmission is to see how it shifts and if it can use all gears.
Without documentation of the timing belt, you already know it could be a potential ticking time bomb and you'll be running on borrowed time. It's not a difficult job and the parts kits aren't expensive.
I would go ahead and change it immediately if you purchase the car, I'm assuming if you're a VW/Audi guy you'll find the job to be pretty straight forward.
I assumed the Volvo would be as difficult and just decided to take it to a mechanic. But if it's easy, I'll do it myself.
Ooh no doubt. Is the timing belt under the engine casing on the S60's? I'll look into it but I don't have the tools to get deep on the engine (on be our audi at least).
Haven't done it myself yet as I totaled my '02 before I got the chance, but the youtube videos make it look fairly straight forward. Recommend replacing the tensioner at the same time and setting the tension is a critical step dependent on temperature so just make sure you know the ambient temp where you are working.
