Issues with the automatic window regulator
Old 10-31-2023, 03:10 PM
Gillito's Avatar
Default Issues with the automatic window regulator
On my wife's 2008 S60, the automatic window is Not working properly, when the window goes up it doesn't stay closed, it reopens the window unless you hold the button on the up position..
I tried holding the button on the up position as suggested but unfortunately didn't work.. any suggestions?
Thanks in advance!
Old 11-01-2023, 10:26 AM
Sounds like the switch or auto-up/down circuit is not working. Theres some vids on youtube on how to reset the window, check fuses etc that may help.
Gillito (11-01-2023)
Old 11-01-2023, 04:11 PM
Gillito's Avatar
Thank you for the tip, the 'remove the fuse while the window is going down' trick did it, now the automatic window switch works as designed, which I am very glad as a new (OEM) switch cost is over $450.. Thanks again!
Gtallard
11-10-2019 09:36 PM
reecesp1eces
02-02-2014 08:44 PM
daver80
04-22-2011 12:13 PM
steved
12-20-2008 05:37 PM
jmaslanka
11-27-2008 07:30 AM
Quick Reply: Issues with the automatic window regulator
