Transmission Hesitation From 2nd to 3rd Gear
My '02 Volvo S60 T5 has about 75K miles on it. Recently the transmission has been hesitating when shifting from 2nd to 3rd gear. In fact, what happens if I'm not careful is that as the transmission hesitates the rpm shoots up cause I have my foot on the accelerator, when the transmission catches there is a hard jolt because of the high rpm's. I've learned to back off on the accelerator during the shift from 2nd to 3rd gear.
I found the transmission dipstick (the yellow one) and checked that this afternoon. The car was running and up to operating temperature when I checked the fluid. There seems to be enough transmission fluid in there, although the dipstick doesn't say "min" or "max", it says "cold" and "hot". However, the transmission fluid is a dark rust color, almost brown. I believe transmission fluid is supposed to be bright red. Anyhow, I'm wondering if old transmission fluid could be the culprit for the hesitation and hard shifting I am experiencing as of late. I did have the car down to Volvo several months back when we were having some shifting issues. They reprogrammed the computer and that seemed to take care of it until now. Thoughts? Thanks! |
That is possible.(Fluid)
Also there might be a software upgrade to help. |
Originally Posted by tech
(Post 152551)
Also there might be a software upgrade to help. The last software upgrade was done last Fall. Would there be another one out so soon? |
It is possible there is new software but there might not be I would ask.
I just called the nearest dealership about getting the software update for my '01 S60 2.4T and it's going to be $115 for labor and $30 for the software. Wow. I have to drive 200 miles to get screwed in my butt.
Originally Posted by CASS60
(Post 154147)
Originally Posted by Somthngfrce
(Post 154159)
You just made me Chuckle...,lol.
The really sad part is the labor charge should only be a half hour and they charge 1 hour.
But in a way we all get screwed in the butt with something on our Volvo's. |
Mine has a similar problem that new transmission fluid didn't really fix. Does anyone know when the newest software update came out? I know mine had a software update in '07, but I'm curious if there was another since then.
(Post 154247)
