Transmission service required
![Smile](https://volvoforums.com/forum/images/icons/icon7.gif)
Volvo S60 2.4t 2001 86000 miles. Yesterday when driving from work I notice there was something strange with the transmission since the changes between gears were a little bit rude. Today the failure got worst, when stopped the car shift gears even with the brakes ON and the "TRANSMISSION SERVICE REQUIRED" and "CHECK ENGINE LIGHT" turned ON. I connected the scanner and got "TCM-0 neutral check, 12B no neutral check” code. I had the transmission fluid replaced 4 months ago, oil color and smell is OK. I was reading all the posts about transmission issues and seems that the issue is related with the control module adaptation but since I am outside the US updating the software for this car is almost not an option (the only Volvo dealer here wants $900 just to update software and no guarantees this will work, I know more about this issue than them). Any advise, will be very helpfull...
thanks for the reply,
Just a small explanation, I am located in el salvador central america and we only have 1 volvo dealer here... I got the issue fixed, I changed the oil and errased the code, so far so good I think I will keep testing the car... 6 months ago I changed the oil and I am sure it was the correct oil since I got the oil from the dealer, maybe a mistake here... Thanks a lot for the reply.
hours
12-26-2014 09:37 AM
bradleyduncan
07-07-2011 10:32 AM
icehouse719
11-10-2010 03:31 PM
chrissygm
09-30-2008 05:53 PM
