Turn Signal Switch Failure
I'm having a problem with my 2013 S60. I had the same problem with my 2010 S80.
The turn signal switch detent is failing. When I am signaling a lane change, the switch goes beyond the detent and sticks in the "on" position. When I cancel it, it sometimes goes beyond the center point, past the detent, and sticks in the "on" position in the other direction. When I had the 2010 S80, the same problem occurred. I had the switch replaced under warranty. The new switch developed the same problem. Now I'm having the problem with the S60. My next step is to go to the dealer to see if they will replace the switch. Has anyone else had this problem? When I googled "Volvo turn signal failure", I got a number of youtube hits showing how to replace the switch, suggesting that this is not an uncommon problem. |
Please post your car issues under your cars sub topic and not in new member.
