Turn Signal Wire help
Old Mar 1, 2014 | 10:57 AM
mike0116's Avatar
Default Turn Signal Wire help
I have a 2007 S60 2.5t awd with bi-xenon.
I am currently switching my turn signal bulbs out to LED's. I was wondering if anyone knows what wires are for the turn signals. I need to put resistors in to keep from hyperflashing. In the rear, the lights are all on one plastic bracket that holds the lights.
I checked and saw on the driver side 2 gray, 1 solid green, 1 solid blue, and 1 solid black.
On the passenger side there is 1 gray, 1 solid blue, 1 Green w/ white stripe, and 1 black. Which one(s) are for the signals??
PLEASE help!!
Old Mar 1, 2014 | 11:03 AM
pkrface's Avatar
Just pull the tail/turn light bulb housing out as if you were going to replace the bulbs and turn the turn signal on to make sure you are identifying the right bulb then you know which wires are involved. Use a test light to make sure you know which wire is the power side. The light will flash when you contact the correct wire with the turn signal flashing.
suckonthiscaravan
Dec 5, 2018 03:19 PM
clean850R
Jul 25, 2011 07:01 PM
CactusTaxi
Sep 2, 2010 09:30 PM
brennanpersonal
Nov 4, 2009 10:33 AM
rspi
Sep 2, 2009 09:39 PM
