Emissions code p2404 evap system
Has anyone had any trouble with this code popping up? I have a 2007 S60 T5 with this code and possible issues are, purge control silonoid, charcoal canister, holes on vacuum lines, faulty pressure or flow sensor. I would prefer not to throw a lot of money at it. I’ve seen it could also be the gas cap, but mine seems fine.
P2404 Description The Engine Control Module (ECM) checks power consumption on the Leak Detection Pump. The Diagnostic Trouble Code (DTC) can be diagnosed when the leak diagnostic system is run. A diagnostic trouble code is stored if the current consumption of the pump in the Leak Detection Pump unit varies too much during the reference phase.
Read more: https://www.engine-codes.com/p2404.html
