-   Volvo S60 & V60 (https://volvoforums.com/forum/volvo-s60-v60-10/)
-   -   Valve seal replacement (https://volvoforums.com/forum/volvo-s60-v60-10/valve-seal-replacement-117236/)
RPMCanes Mar 17, 2025 07:35 AM
Can you replace the valve seals without doing a full cylinder head rebuild?
hoonk Mar 17, 2025 09:22 AM
With the head still on the block? Not easily - (remove cam cover/cams. pressurize each cylinder with enough air pressure to be able to compress the valve spring without opening the valve, remove keepers spring and seal, then reverse the procedure) - and valve stem seals are not going to solve your oil usage problem.
