volvo s60 no power, accelerates very sluggishly
HI new member here. Im having a problem with my 2003 volvo s60 2.4T. when i am casually driving, the car drives like it is 100 percent. However when i go to accelerate aggressively, the car acts as if i am only holding the gas pedal half way down, accelerating very sluggishly. Launching from first gear at full throttle the car will move through first gear accelerating up to 4000 rpms then shifting to second. then accelerating to 4000 rpms again before shifting to third. once the car finally makes it to third the car will accelerate to about 4000 rpms before it stumbles and trips on itself. (feels like it is shifting between third and forth gear rapidly or feels like engine is cutting in and out). if i continue to hold the gas pedal 100 percent down the car will continue to trip and stumble until it falls into safe mode. the car does not have enough power to overtake other cars on the freeway and cannot climb hills at all. ive taken the car out to open country roads and opened up to full throttle and car can only made it to 92 mph after a very very long time and would not go any faster. ive taken the car to 120 without any problems before this new issue. the way i get the the car to highway speed is by manually shifting for the car so the rpm stay below 4000. i have checked the TCV, the boost pressure sensor and Mass Air Flow, all seem to be in working order. The fail codes i have gotten are P0236 (Turbo Sensor) and code P0237 (Turbo circuit A low). fail codes will sometimes be present and sometimes not.
so i spent the day under the hood and found that my turbo has seized up, the shaft connecting the turbine to the compressor bent and snapped. i pulled it out and have taken the turbo all apart. does anybody know of a good rebuild kit for the turbo or know of any volvos that use the same turbo. thank you
T
T
endx
06-03-2012 08:46 AM
hardluck
03-03-2012 02:20 PM
