What do you call these and where can I find some new ones ?
Old Nov 13, 2012 | 05:18 PM
Derdertim's Avatar
Default What do you call these and where can I find some new ones ?
Ok so video# 1 of may to come. Please watch the video and let me know if u can help
Thanks -Tim R.
Old Nov 13, 2012 | 05:19 PM
Derdertim's Avatar
Old Nov 15, 2012 | 05:57 PM
01_fast_ride's Avatar
Hi Tim,
To say that you have a problem is an understatement. Those don't look like stock parts. When you did the struts yourself, did you save any of the original pieces or was it pretty much like that before you started?
The sleeves that you show look like remnants of the old spring seats. The spring seat is that hard rubber black part. When you get serious failure of that part the steel tube will separate from the rubber and your suspension will feel squishy and knock a lot from the movement. Did you replace the spring seats when you did your struts. If the sleeves are from the spring seats and you put them back in with that kind of damage, that is your problem right there. Order new spring seats immediately.
Old Nov 23, 2012 | 12:36 PM
JRL's Avatar
JRL
You NEVER, EVER replace struts without replacing the spring seats (That's what these strut mount rubbers are called)
You only use either OEM Volvo XC90 spring seats or IPD HD spring seats, all others are junk
Old Nov 26, 2012 | 03:58 PM
Derdertim's Avatar
Default Ok..
Ok I ordered new spring seats, now where do I get to rubber peices that go on top of the frame around the strut refer to the first half The video).
Old Nov 28, 2012 | 04:27 PM
Here's a diagram of the parts
Check with them. Or try the dealer.
rspi
May 10, 2011 10:25 PM
yungprofit703
Mar 23, 2011 08:52 PM
jjstahl3
Jul 16, 2008 06:41 PM
ludeless
Dec 17, 2005 07:14 PM
